Workshop Heaven Passaround
miles_hot":2plmvxrk said:
jimi43":2plmvxrk said:
Flush saw...appears to have a kerf.....mmmm need to test that as I thought it should not have ANY kerf.....seems very sharp though...like a tiny clone of my bigger Japanese Ryoba....
Later guys and gals.
Jim
Did you mean kerf? :shock: :D Maybe you meant set? :)
Miles
Yeh....I meant set! DOH! My excuse was that Mr McAfee meant that I spent 18 hours at work today and me brain fried!!!! :D Damn work...puts a right mockers on yer whittlin'!
:wink:
Cheers Miles...I would have been distraught had I created the wrong impression! 8) :D
Jim
Ok..the sun was out today so for those of you who have not seen the kit...I took some pictures. I am on my last shift this week at 3pm so this has to be short and sweet...
The tools:
The mortice chisel will need a little honing to remove the burr rollover from previous work...
It seems very hard steel! Very functional...use review later but it is well made with a nice beech handle and brass ferrule:
The RK bevel gauge is nicely made...small and functional:
More tests on that tomorrow....
The Japanese flush cutting saw...
Cheaper handle than the rest (aren't they all like that) but mightly sharp (ouch!)
and finally...the rasp...
Nice beech handle again....quite small...which is just what I need...and appears to cut very well on the oak scrap that I tried...more on that later...
SO...that's the quartet...in the beautiful Kentish sunshine...
Thought I would get them up so you guys and gals can see them at their best before the sun goes in again! :wink:
Testing tomorrow after a morning at the bootfair....
Jim
They look good in the sun! Is this pass round never ending, could I join or are they destined to return to their owner soon?
Ok...the refurbishment of the steamer recliner took a lot of today up which was not planned BUT it does mean that I can test these tools tomorrow in anger on REAL work...when I make the mortice for the new leg I have to make.
I can also fully test the rasp on the leg because the end is contoured.
ANYWAYS....off to the test....
First..I tested the flush cutting Japanese saw. Now as I said, I could feel a set on this saw and so I was rather sceptical as to whether it would work without leaving any scratches...which is the whole point of these saws...
The first test:
For this test I decided that I would use oak as the dowel....a hard wood...and I embedded it into mahogany which was somewhat softer and would show any scratching if it occurred.
I am not 100% on how to use these things as this is the very first time I have had the luxury....but I bent the handle to keep it away and started hacking....
Well that's it....cut through REALLY easily! This thing is sharp and very controllable...
Yes...there was dust...BUT.....
I am very surprised and pleased...as you can see...not a single scratch...perfectly flush and beautifully clean!! I WANT one!! This was a very pleasant surprise indeed!
The second test was using the Richard Kell adjustable 4" bevel gauge....now I feel this is eye candy but not quite functional...I don't really like smaller adjustable gauges...I prefer fixed ones for purpose...so how did this perform...
Well...I set it to roughly 90 degrees and scored some lines with my new homemade marking knife. It felt quite small and almost uncontrollable....had a tendency to slip...but I have large hands...
I set a rough 6-8 degrees for a dovetail bevel and marked again...still ok but a little awkward.
Then I got bored with that little device and decided to see how the flush saw would cut the dovetail sides....REALLY impressed!
How accurate is that!
Of course...the observant will see that this "dovetail" is inside out...I just started hacking away without thinking. Tomorrow I will try this saw on a few real hand dovetails to see how well it performs over the Ryoba!
To be realistic...the new adjustable Ryoba saw that I have would make easy work of this but even though this saw is very small and flexible is performed beautifully!
So...the tool that I was almost sure would be superb...the RK gauge...was just ok...too small for me...but the saw...well....BRILLIANT!
Now on to test THREE....the little rasp! The one that I was dying to try...
Now this tool is really NICE! It cuts with little effort and for a course rasp...it is relatively close to finished texture. It is nowhere near as brutal as my big bastard rasp....and you get the feeling that you could whittle something rather complex...we shall see! Watch this space!
So...swiftly on to test FOUR.....the mortice chisel....
The prep for this was a roughly marked rectangle (of course)....
This cuts quite well really...
I prefer my old Sorby of course but that sort of quality these days would set you back and arm and a leg...so let's be fair...this little baby does a hell of a good job.
One thing that I noticed was that it was remarkably comfortable...in fact...very comfortable...which wouldn't strike you given such a plain tool. It sets out to cut mortices and that's what it does...effectively and cleanly. And I only had to use my very small iron adjusting mallet to tap it too!
Well...that's the lot guys...rather basic tests....not in anger on a real project until tomorrow....but I hope this gives you a viewpoint....
But before I say tata for the night...Matt sent me a little gem which I will be testing tomorrow for him...but here is a sneek preview...
Now this IS a real beauty...but I will keep that review for a separate thread....
Cheers :wink:
Jimi
