devonwoody":1r7rqqa9 said:...roof is one of my next jobs when I can get some help. (I have a storeage site for the asbestos).
OK, I'd say you need to assess the structure as a whole. It sounds like putting heat in at present is just going to result in it being thrown away as soon as you generate it. You have double glazing, so that isn't going to be so much of an issue. However, the roof will lose loads of heat unless it's insulated, but so will the door - especially if your door is a thin flip-over style door and even worse if it's metal. Thin concrete floors tend to be a source of both damp and cold, especially if they are unsealed and lack a DPC. And working on cold concrete floors for extended periods can exacerbate chillblanes, etc. Whilst thin single skin walls are another area where heat just pours away.
You can get really cheap, even free, insulation if you look around - for example, how many expanded polystyrene packing pieces do you, your family, assorted workmates and neighbours throw away each year? Were you aware that straw bales are essentially a waste product in cereals growing areas? but are excellent insulation - although they do need to be kept dry and allowed to breath.
So I feel that putting in heat, whilst essential, should be accompanied with a bit of extra insulation.
Scrit
