garywayne
Hi folks, I hope you all had a good christmass and new year.
I am in the prosess of draught proofing under my stairs, but before I can finnish off I need to run cable from my consumer unit and under the floor.
When it comes to electrics I believe that I am capable to do the job. What I don't know is, what is needed, or what ratings.
In the shed I will have:-
1 x Lighting circuit. ( 6 double florescent lights).
1 or 2 x ring mains. ( With lots of sockets).
1 x Table saw, (I believe running from a 16A MCB).
1 x Bandsaw, ( depending on which one, pos running from a 16A MCB).
1 x Planner\Thicknesser.
1 x Extractor. Don't know what one.
Power tools running from ring main.
Sorry if I am dragging on a bit.
What I need to know is what size MCB will I need in the consumer unit, house side, and should it be RCD protected? What size T&E cable will I need to go from the consumer unit to the Armour cable, (What size Armour cable)? I take it I will need the same T&E from the Amour cable to the shed CU?
I think the rest is pretty straight forward.
I will be getting a part P electrician to test and I hope pass all of the electrics once I have finished.
