Yorkshire Graham
Hi. Sorry to come along with a long, rambling question so early in my forum membership.
I’m interested to know forum members' views on workshop ceiling height. I’m going to convert my garage/outbuilding into a workshop and I’m hoping not to make a poor decision right at the outset. The first thing I want to do is insulate the roof.
The building has great potential – it is approx 9.5m long by 5m wide with a pitched roof. The maximum height down the centre (to the underside of the ridge) is 3.75m reducing to 2.5m at the wall plates. To get better insulation and reduce the volume to heat, I am thinking of putting in a false ceiling with plenty of insulation above. There are a couple of very heavy beams across the building which would conveniently support ceiling joists and that would give a finished height of 8ft (sorry to mix up units). That is the most convenient height from the construction point of view and gives maximum insulation potential, but I feel I might regret this every time I stand an 8ft sheet on end! It’s not a big deal to put the ceiling at any height, but I would like it as low as is workable for heating/insulation reasons. There is also a good chance that I’ll end up with a wooden floor to further improve insulation, so I should allow a few inches for that.
The workshop will be used for general hobby purposes – making a bit of fitted furniture, some new kitchen unit doors etc. and just generally escaping. The largest project on the horizon is the possibility of making a summerhouse, but a lot of that would be done in situ, I imagine.
So, do people think that a ceiling height of just under 8ft is perfectly OK or should I use a bit more of what is available? Thanks in anticipation.
Again, sorry about the ramble.
Graham
Graham
