Working with Shagreen
Ian
5 Apr 2007
Northern Ireland
Hi
Anyone have any experience working with shagreen?
I have been asked to make a box covered in shagreen and was wanting to know about some techniques and what type of glue / finish to use.
I have sourced some hides and am quite keen to take on the challenge but need some help.
Or perhaps someone knows of a book out there with some help.
Ian
I've never used it myself but have done a bit of research 'cos I've always wanted to try it, but I was told it's very difficult to cut by a design lecturer, who I don't think ever used it herself... Ebay reckons it's easy to cut with scissors though :-k
Thanks guys
The guy on ebay said he would send a few offcuts to try out so it will at least give me and idea.
Ian
I've used it before for wrapping katana handles. It works well using ordinary PVA. I would recommend that if not using shagreen as a textile (wallets etc.) scrape most of the "leather" off the back at least until you can see the outline of the nodules (soak in water first). This helps get a better fit and gives a stronger bond. I thought it was fairly easy to cut provided you dont try to cut one of the nodules. I found the small leatherman micro scissors to be perfect for this job. You can't cut dead straight lines, you cut in a zigzag around the nodules. This does have an advantage in that joining two pieces together can easily end in a seamless result if you get the fit right. The material can stretch a bit as well. The nodules will sand well on a linisher, but they smell a bit. Glue up when it's been well soaked and still moist (because it retains its flexibility) Shagreen (particularly when it's been shaved) becomes stiff when dry.
Hi,
There was an article a couple of months ago in F&C about it.
