Adam W.
A Major Clanger
I don't have such trickery in my shed.
I did try with a finely sharpened 'stick' but the Titebond I'm using even picked up on that was too large to get in the 1.6mm holes so I resorted to the stick to get the glue out of the bottle and the scalpel to pick up a smaller amount to press into the holes.J-G your comment about applying glue with a scalpel made me smile. I have resorted to a toothpick before now.
small paint brushI did try with a finely sharpened 'stick' but the Titebond I'm using even picked up on that was too large to get in the 1.6mm holes so I resorted to the stick to get the glue out of the bottle and the scalpel to pick up a smaller amount to press into the holes.
Too 'floppy'.small paint brush
Buy "stiff" ones. There is a huge variety available. Or a cut down soft brush is stiffer.Too 'floppy'.
Similar one on site, engineers work to 100th of mm and the chippies work to bang on!One of the "wind-up" quotes in the Royal Navy was that "Shipwrights measure to the nearest Ship". Not that such a quip would pass my lips!
Nowadays they have a virtual bubble on their mobiles.They needed a new bubble for their spirit level.
Fortunately I don’t build houses........Or the nearest house.
Have you tried a syringe, it depends on the glue being used but I've used one for PVA, that got through the needle.I did try with a finely sharpened 'stick' but the Titebond I'm using even picked up on that was too large to get in the 1.6mm holes so I resorted to the stick to get the glue out of the bottle and the scalpel to pick up a smaller amount to press into the holes.
No. I suspect that it would be more trouble than it is worth and certainly take longer to first fill a syringe and then dispense the small amount which may well 'cure' before I'd have time to turn the plug and position it over the hole.Have you tried a syringe, it depends on the glue being used but I've used one for PVA, that got through the needle.
