billw
The Tattooed One
OK so very very much inspired by Dennis from Hooked On Wood, I sketched this up last night. It's not perfect but it's as good as for now. The frame is all 18mm ply, the work surface is 19mm Valchromat. It'll be resting on 72mm castors giving an overall height of 865mm and dimensions of 1200x600.
The 20mm holes are all 100mm apart centre to centre, even round from the top to the front (although why that helps I dunno). I haven't followed the 96mm Festool system because 1) I don't need to 2) it doesn't make much sense to me anyway and 3) this spacing fits the benchtop size perfectly. All the holes on the front are fully accessible, although the second row down only has 18mm of space behind it. To compensate for this there's the grooves for clamps (I've copied how Dennis did his, basically routing what looks like a dovetail shaped groove, I haven't looked at whether t-track is better) so really the only thing you need to put into the front holes are dogs.
As per Dennis, the underside is left open in case anything falls through the bench for easy retrieval. All seems pretty straight forward to build! BAse unit attaches to the top using metal corner brackets.
If anyone wants to have a play around with the SketchUp file, let me know - seems I can't attach .skp files to a post.
