Ha ha.You snuck that one in after I posted, perhaps you're a lost cause
You’re not just paying for a name that is marked on it. Let me guide you though the process for making a stainless steel t Sqaure. The handle has to be milled from a billet of aluminium. Our design takes 28mins for op1 and 2. The stainless steel blade is laser cut from a sheet of 1.5mm 304 stainless steel. We get from this sheet 1mx1m 13x610 and 8x410 blades. This takes about 1.5hrs and half a bank of nitrogen. We then machines each blade in the mill to ensure the blade is square and has a diamond cut edge. This is then checked. On the cmm. It is then glass beaded to give it a Matt finish which also makes the number more visible. The laser process for the markings take a further 40 mins to complete. We the. Process this though our arku. Which is a flattening machine. So the man hours to make one t square is about 3-3.5 hrs per square. I can also give you some figures on what is required to make these.I have a 600mm Chinese one, and it is as accurate and square as I can measure. Cost less than £30 delivered. I also bought a pocket one that I keep on me at all times, and that is also square. I personally don't like paying for the name etched onto a product.
