James C
After years of waiting I should soon hopefully be in a position to construct myself a workspace at the bottom of my garden.
My plan is to assemble a 40mm thick log cabin which can be viewed on the link below.
https://www.tuin.co.uk/Aiste-Log-Cabin-5-x-3m.html
To try and keep costs down, and so that I have completed some of the construction myself, I am planning to construct a wooden base for this using 6x2s bolted down to 4x4 posts would be fixed in 12x12 holes with postcrete or a similar product.
The plan is to make a base that in total is 16x12 for a 16x10 log cabin. I would then deck the 2' of base in front.
https://ibb.co/0YYCpZW
This is looking sideways on with the longest span running away. On the right you can see where the decking would be supported with two joists. The main joists that are not attached to the posts are currently at 350mm centres. I have yet to add any noggins to this design, as I want to get the joist spacings correct first.
Bearing in mind that I plan on adding a large workbench, 140Kg Bandsaw, 85KG Morticer as my heaviest items of machinery, do I need to have narrower centres for my joists? Should I add an extra row of 5 posts?
Any help and guidance would be appreciated.
