joiner_sim":39ry6r17 said:erm.... just an idea, it might be plain stupid, but what about cedar?
Interesting - what makes you say Cedar and indeed what makes you think it might be daft??
Miles
Thanks for the pointer - looks a good option. You recommend western-marinemarcus":8169tcjk said:You can get marine ply with a decorative veneer - usually oak or teak - it's used a lot for boat interiors. It's not cheap though! Try Robbins http://www.robbins.co.uk/mar_lamply.htm
As has been mentioned you would need to varnish it - you could use a two part varnish http://www.western-marine.com/page75.htm and then hopefully you won't have to keep on varnishing every couple of years....
Marcus
marcus":2umuuyx7 said:Hi Miles,
NB Don't know if you've used teak much, but it's worth noting that the high oil content means that sometimes you need to use special primers for varnish & paint - depends on the product - it's worth checking before you buy.
Marcus
miles_hot":3ul10gxt said:Tusses":3ul10gxt said:I'm sure a friendly local forum member would be happy to help for beer tokens
True - anyone local to me? I live between Swindon and Newbury...
Miles
9fingers":7cgk7mfn said:miles_hot":7cgk7mfn said:Tusses":7cgk7mfn said:I'm sure a friendly local forum member would be happy to help for beer tokens
Miles
I can rough cut, joint and thickness your timber for you if you like.
I'm about 40 miles away in Romsey. No beer tokens needed just happy to play with wood.
Located at SO51 5RS Weekends ideal, weekday evenings should be feasible too. You can see the Burgess cyclone working too!
Bob
