Good Morning All,
yesterday I had a look at some American poplar which I've had stacked in my workshop for about six weeks and was shocked to see how much wind it has developed. I put this down to it having come from the shed of a timber yard in January into a relatively warm workshop i.e. it's probably drying out too quickly. The pieces are about 4' long and were destined to be used to build a book case. The high corners are now a good 1/4" clear of the flat surface I laid them on. To flatten them would obviously mean losing a lot of thickness in the final pieces.
As it happens I can use one or two 3' pieces at about 1/2" thick for another project but that will not use it all up. In order to retain maximum thickness my first thought is to half the wood in its length and then again rip it to half its width so a piece 4' by 6" would yield four pieces each of 2' by 3" while being able to be planed to a useable thickness. However, this would result in boards looking for a use which seems a bit cart before horse to me although uses would inevitably be found.
Would it make more sense to lop off the ends where the wind is at its most dramatic thus salvaging something useable from the middle which would at least be full width?
What do you do when confronted with wood like this?
