Window Board Secret Fixing
Garden Shed Projects
UKW Supporter
21 Apr 2021
Northamptonshire
Hi can any one offer any tips for secret fixing a window board. I have one to fit at 3600mm x 350mm in my extension and am thinking gripfill or similar but wondered if there was any innovation or technique I am not aware of. The walls and reveals are already plastered.
Any ideas greatly received.
Hybrid silicone? gripfills OK but not used loads these days(I've not used it for over a decade) gun grade pu foam which is what phils saying?
Hybrid silicone is used for everything
Plumbing decorating sealing gluing but it's real sticky messy muck for sealing stuff not recommended. Normal silicone works fine to.
One way to do this mechanically, is to rely on a fix at the back of the window board, using a bare face tenon along the length of the window board, inserted into the groove on the inside of the window sill.
The front is fastened down using Galvanised strap or angle brackets screwed to the underneath of the board, and to the wall beneath This is more convenient to do before plastering, but it is a simple enough operation to house the straps deep enough into the plaster and fill after fixing.
EDIT.
For a really neat fix, the sides of the window board can be partly recessed into the reveals, cutting the tops and bottoms of the housing with a multitool, before chiselling out the waste, and filling after the board has been installed.
Use a t slot cutter to put a few of slots in the board from the back edge to about three quarters of its width. Do a small test bit to the same depth.
Mark the positions on the substrate and install some pan head screws in line with the slots using appropriate plugs or whatever, 2 per slot, front and back.
Use the test bit to check the height of the screws and when its just right slide the board in. You want a little bit of resistance but not loads.
I am assuming a solid wood window board, I have done it on loads of Oak ones and some Utile, might need to be careful on MDF as its quite weak.
Use a bit of stixall or other hybrid polymer as well if you feel like it.
I’ve recently removed some new skirting that had been fixed with foam & plasplode nails, it came off surprisingly easily. It wouldn’t be my choice for fixing window boards.
All those in my extension, similar construction and MDF boards, were done using the solvent version of Screwfix own no more nails. Solid as a rock. Any exposed block work can be sealed first with PVA.
Method like Ollie's if they are solid wood in case they warp. I only have one original window board in the whole house. Solid pine installed in 1918, and assume held in the same way as the others with cut nails into wood noggins between the bricks. That one is distinctly bendy in both directions :)
Interestingly I found that skirting boards held on with solvent free no more nails can actually be peeled off as it were using a thin pallete type knife, and leave nothing behind but a slight discolouration of the plaster.
Never had one come free on its own, but relatively easy to remove if you do need to.
I put all mine on this way and have never had one come off in twenty odd years, but have had to remove a few sections for one reason or another and fully expected to have to do a bit of remedial work on the plaster, so quite a bonus.
If the wall isn't quite flat then I just screw a batten on the floor about a foot in front of the skirting and use off cuts to wedge against it while the glue dries.
