scooby
Hello
I only have rough dimensions at the moment, but I need to make a cabinet of around 20" deep, 36" wide and 60" tall. Open front with 2 horizontal shelves.
The cabinet is visible from both sides and being open fronted I need to use a fixing method that can't be seen. Normally, that wouldn't be too difficult but the material is 5/8" beech venneered chipboard.
I don't have a dowel jig but I do have a biscuit cutter for my router. Would biscuits and glue do the job or should I use dowels (and measure them out carefully as I'll need quite a few along the 18" edges).
I was considering getting a pocket hole jig to give the biscuits a bit of added strength, even though getting screws to grip in chipboard can be a hit and miss affair.
So it's either :
1. Drill a lot of dowels 'free hand'
2. Biscuits and glue
3. Biscuits, glue & pocket hole screws.
If no.3 sounds feasible could someone recommend me a reasonably good pocket hole jig (mainly used for 5/8" & 3/4" thick materials). Something around (or under) £25?
thanks
So it's either :
thanks
