Robbo3
Only used on cold ash raked out before relighting fire.I can see that going up in smoke one day.
Ive got a dw745. My blade area is enclosed ( factory ) and a George hoover fits perfectly in the adaptor for site use. The 68mm downpipe fittings are plumbed into my workshop extractor.I have same or similar saw and would appreciate a few pics i
of your mods as a comparison to mine . I did have to seal the chamber that encloses the blade and used 68 mm down pipe to connect to my vac /cyclone and also tee,d off to provide extraction to the guard ..I discarded the adapter which came with the saw
The Oneida cyclone came with a grounding kit ( aluminium tape and a tag ) to connect to 1 of the securing bolts then a length of copper wire is used with a flat washer resting on the floor. My other generic cyclone doesn’t have the grounding ( as yet ) but having used my planer for a couple of hours I noticed every time I emptied the tub I received a shock due to the build up of static within the container (I assume) it’s worth adding as it doesn’t happen with the Oneida. Will send picks later tomorrow.I've just bought my first cyclone Cyclone Dust Collector Separator For Shop Vac, Separator Dust Powder Filter For Vacuums Dust Extractor Accessories Woodworking - Power Tool Accessories - AliExpress
I already have a blue bin to connect it to
Pics of the grounding kit supplied with Oneida cyclone -easily achieved with aluminium tape , wire and a cable crimp -I’ll fit one to my other cyclone at some point .The Oneida cyclone came with a grounding kit ( aluminium tape and a tag ) to connect to 1 of the securing bolts then a length of copper wire is used with a flat washer resting on the floor. My other generic cyclone doesn’t have the grounding ( as yet ) but having used my planer for a couple of hours I noticed every time I emptied the tub I received a shock due to the build up of static within the container (I assume) it’s worth adding as it doesn’t happen with the Oneida. Will send picks later tomorrow.
I got the idea from a video series on Youtube by Ohyo56. If you can find it, he gives a video that pretty well shows what he did. I had to modify his pattern to fit my saw as mine is one of the very early ones with the plastic housing so there are many differences in it.I have same or similar saw and would appreciate a few pics i
You just think it's enclosed. It's got a large area at the top that is wide open and it lets a lot of the sawdust out. Watch the video by Ohyo56 on Youtube and you'll see what he did and got almost 100% capture.Ive got a dw745. My blade area is enclosed ( factory ) and a George hoover fits perfectly in the adaptor for site use. The 68mm downpipe fittings are plumbed into my workshop extractor.
I find the lower extraction is very good. I need to make a new crown guard to get the top extraction better ( its an aftermarket 63mm currently )
I found the video..... I'll have a look at my saw next time im at the workshop. To be honest, im probably too lazy to make that......
I didn't find it a problem by just watching the video a few times and comparing it to my saw. I'm sure you can do the same.Yes I also found the video and I’d really like to make it but there is no audio to go with the video-reminds me of building my greenhouse ( aluminium frame and glass) via pictures for instructions it was really difficult and I reverted to trial and error and eventually got it done. My saw is about 3 years old and had a similar plastic enclosure around the frame. On a positive note the results are truly impressive.![]()
Fair enough-I’ll give it a few watches and give it a go , admittedly I had my son trying his best to convince me he needs a computer and a VR headset and a ps5 for Xmas so the thought of several hundred pounds of money I don’t have was probably a little distracting.I didn't find it a problem by just watching the video a few times and comparing it to my saw. I'm sure you can do the same.
Whenever I told my Dad that I "wished I had" anything, his standard reply would always be "wish in one hand and **** in the other" and then you'll find a way. I mowed lawns, washed windows and cars and tossed newspapers. I ALWAYS bought what I wanted. Kids today are spoiled.Fair enough-I’ll give it a few watches and give it a go , admittedly I had my son trying his best to convince me he needs a computer and a VR headset and a ps5 for Xmas so the thought of several hundred pounds of money I don’t have was probably a little distracting.![]()
He’s autistic and he knows itWhenever I told my Dad that I "wished I had" anything, his standard reply would always be "wish in one hand and **** in the other" and then you'll find a way. I mowed lawns, washed windows and cars and tossed newspapers. I ALWAYS bought what I wanted. Kids today are spoiled.
That makes a difference.He’s autistic and he knows it![]()
