transatlantic":3ofytj6j said:
I confused matters with posting that image I think. The following image shows more what I was describing, but imagine the tails being much longer, and the angle being much less severe. Hence my analogy to a 'dovetailed Mortice and Tenon', as oppose to a sliding dovetail that is usually very small.
Not a bad choice at all for three legged tables, even if used on just one leg to allow final assembly. The alternative to sliding dovetails, tapered or not, would be M&Ts that need to be sloppy so that all parts can be wriggled together - not a great option, or an adaption of the M&T in the form of a bridle joint so that each rail can be slipped into place individually, also probably not a good technical choice. Webbing clamps could be one method to apply pressure, for the M&T type variants, and even for the sliding dovetail if required. Slainte.
