Rob Lee":29cwfbwl said:Neil":29cwfbwl said:I hope a compass plane is on it!
Cheers,
Neil
That's the list I see when I have nightmares..... :lol:
Paul Chapman":37xyytom said:I agree that it's probably a tool that you wouldn't use very often but when you need one, you need one.
Cheers :wink:
Paul
Smudger":ol4kprqr said:Do I really NEED 3 Record 04s?
marcus":14mk67rx said:Yes a compass plane would be nice wouldn't it! My ( slightly unrealistic!) wish list for new Veritas planes also includes:
- Combination plane (for mouldings, to keep it simple and usable) in which each cutter has a little matching sole you attach to the plane body in front of it, so that you get a proper mouth for them all. Can't you just see the wooden box with all those cutters and soles lined up in it . I would want it to include cutters for hollow and rounds, cove, slitting, ovolo, beads and flutes.
- A set of dado planes (or a combination one with replaceable soles as above)
woodbloke":14mk67rx said:At the risk of having cyberbricks lobbed in my direction, a compass plane would be a pleasant thing to own in the same way the new plough and skew rebate are...but you don't really need them. If you have a decent 'leccy router then everything that these three planes will cut can be done with a selection of router bits costing a few £'s. Curved work is dead easy to do with a template and a top or bottom bearing cutter(s)
Paul - I've not used any of these new up-market speciast planes so can't comment on the finish left staight from the edge, but in my experience with the older stuff (Record 778 for example) I always had to sand in the surface to get it acceptabe...which is what you need to do with a router cut surface. A router cutter costs about a fiver or so from Axminster (and can be resharpened) and will last me about a year, compared to approx £250ish for a plough plane (say) that I'll use just for drawer bottom slips. £250 or £5?.. :-kJust to throw in a different point of view - in my experience, the finish from a well-honed plane blade is usually far superior to that from a router cutter. Second, there are no on-going running costs with a plane - router cutters, on the other hand, are quite expensive and need sharpening and replacing, so the router probably costs more in the long-term.
Having said that, most of us have the planes and the routers.......it's called The Slope
If the piece is too large to use safely on the table then it can be machined on the bench with a hand held router...all depends how you build the jig to do it and how the router is configured :wink: :wink: A decent depth of cut can be achieved using top and bottom bearing cutters, sometimes in combination with a bottom bearing cutter used in the router table (bearing pokes out the top of the table as it's used upside down)That is unless you want to spend the extra time of cleaning up, you can have trouble with chip out and of course the pice may be the large of heavy to safely be handled on the router table, and using the router free hand it can also to unsafe due to size of the bit needed. Or simply because the stock is too thick for any router bit.
woodbloke":2igynpfq said:Paul - I've not used any of these new up-market speciast planes so can't comment on the finish left staight from the edge, but in my experience with the older stuff (Record 778 for example) I always had to sand in the surface to get it acceptabe...which is what you need to do with a router cut surface.
Please explain how that would work, for instance if I was to smooth and clean up the side of a Horta curve shaped cabinet side 24" wide and 47" high, after hogging most material with saws, scrub plane etc?woodbloke":1yp2tc08 said:A decent depth of cut can be achieved using top and bottom bearing cutters, sometimes in combination with a bottom bearing cutter used in the router table (bearing pokes out the top of the table as it's used upside down)
Paul - agreed, it's a shame that you had to give that one back as I'd have liked to have a little play with it last Saturday. Still, look on the bright side...if you don't get socks for Christmas..... :lol: :lol: - RobPaul Chapman":27ry477b said:woodbloke":27ry477b said:Paul - I've not used any of these new up-market speciast planes so can't comment on the finish left staight from the edge, but in my experience with the older stuff (Record 778 for example) I always had to sand in the surface to get it acceptabe...which is what you need to do with a router cut surface.
Pity I had to give the skew rebate back before our winter mini-bash last Saturday because I would have brought it down for you to try out. I think you would have been pleasantly surprised at the finish it gave - the old Record #778 is no comparison (in several respects).
Cheers :wink:
Paul
tnimble":34m06o7s said:Please explain how that would work, for instance if I was to smooth and clean up the side of a Horta curve shaped cabinet side 24" wide and 47" high, after hogging most material with saws, scrub plane etc?woodbloke":34m06o7s said:A decent depth of cut can be achieved using top and bottom bearing cutters, sometimes in combination with a bottom bearing cutter used in the router table (bearing pokes out the top of the table as it's used upside down)
woodbloke":2gf6s7k6 said:Still, look on the bright side...if you don't get socks for Christmas..... :lol: :lol:
Its one of the basic shapes in the Belgium and Frnch Art Niveau substyles.woodbloke":2rmlpkh4 said:Laura - I have no idea what a Horta cabinet is...pics? - Rob
tnimble":399s6l58 said:Its one of the basic shapes in the Belgium and Frnch Art Niveau substyles.woodbloke":399s6l58 said:Laura - I have no idea what a Horta cabinet is...pics? - Rob
Like the curves in this design: (those of the lamp arms, some of the decorative wall painting, and those of the stairs baluster / styles whatshouldtheybecalleds)
(Sorrie I could not find a picture of furniture in this style. Somehow people take photographs of only buildings and almost never of furniture)
Anyhow the type of curve doesn't matter, only the size of the piece the curve is applied to.
Tommo the sawdust maker":304uf5lw said:I think Laura is refering to the work of Victor Horta a Belgian (I think) exponent of "Art Nouveau" I thought this was called paling stijl in the low countries our what we sometimes call eel style.
Regards Tom
