Who has achieved 1000cfm at their static machines (a la Bill Pentz).. if so, how?
Interesting filter box, Heimlaga!
I have a thien baffle setup that I used before moving to a new house (and new workshop). I used to blow the air outside, and it actually filtered quite well. I also had about 100 m to the nearest neighbor, so no-one complained about the noise. However, it did make the workshop cold quite quickly when using the dust collector in the winter.
After moving to a new house, I have been thinking of making a filter box. Both to recycle the warm air, and to keep the noise in the workshop, which should make the neighbors less unhappy. :)
What size cartridge filters did you use? And where did you buy them? Last year I was looking at a filter from Axminster. However, I was not sure if one filter would be enough. Also, after Brexit, the customs fees are expensive, so I'd rather buy from somewhere else (within the EU).
I bought the filters from Dinair in Sweden. The four cartridges are all similar 1200x325mm with the normal number of folds whatever that was.
I designed my DC system aiming for 1000 cfm at the tools. That said I don't have a means of measuring the flow or the dust in the air but I don't get much in the way of chips escaping the machines or dust in the shop. I started with a Busy Bee 5 HP DC unit that draws 22 Amps @ 240V. It has a smaller impeller than Bill P. recommends but it is still rated at 3400CFM.
It came with 1 micron top bags and I use plastic bag liners in the bottom bag. It has a 9" inlet which is reduced to 8" for the riser to the ceiling. From there a 7' header runs the length of the shop. The individual drops are 6" as are the boots on the tools with a single takeoff. I used HVAC ductwork in mostly 24 and 26 gauge. the ducting, boots and elbows are off the shelf pieces. The wye pieces I made myself.
This is the new busy bee CX 15HC (15" helical cutters) surface planer (thicknesser) It came with a 4" takeoff but I made this 6" takeoff with a HVAC 3.25"x10" to 6" angled floor boot. I also fitted it with a DRO with the sensor mounted on the back left corner.
On the the 14" bandsaw I replaced the 4" outlet with another 6" Boot.
I wanted most of the blast gates to mounted on the ceiling so they had to be operated by ropes. I got this idea from Pinterest.
They also work on the wall with an operating rod
I modified the gate design to fit the 6" pipe I was using. Once I had a working prototype I used it for the pattern and routed out the rest with a pattern bit.
I've got more pics, I'll do a second post.
Part 2:
The Rockwell table saw
The 6" drop is split into two 4" hoses. The upper one goes to the over arm blade guard to which I added the 4" elbow. The lower hose just goes into the standard 4" connection on the back of the saw cabinet.
The General jointer,
The 8" jointer came with a sheet metal box under the outfeed table with a 4" hose connection. I changed that to another 6" HVAC boot. It is the centre connection of the homemade slide valve in the picture above. On the right is a floor sweep and the hose on the left goes to the lathe pickup which is still a work in progress. I also have a Dewalt miter saw for which I need to design a dust hood.
Future mods:
- rework the 5 HP DC into a cyclone unit with cartridge filters
- put the router table and a downdraft table into the table saw extension (connected to the DC system)
Part 2:
View attachment 118937View attachment 118938
Future mods:
Most impressive John, really like the blast gates, must remember for my next workshop! Ian
Thanks John. That looks great. I was thinking about putting the blastgates up high too but hadn't got round to figuring out how to operate them- now I know. Ace.
What efficiency is your motor & does it have a VFD ? If not so great (IE 1 or 2) it might be good idea to get a VFD, it should pay for itself in the long run & save wear n tear on the motor.
My progress is glacial but I should be done pruning by the end of March & then have some spare time. I have my 1st impeller ready to weld up. Pics to follow soon maybe.
