Chris152
Barto - looking at this thread, it seems that head would benefit from a fair bit of work to turn into a carving axe, some way above my pay scale?
diy-carving-axe-t93260.html
Chris152":vzawsml3 said:Barto - looking at this thread, it seems that head would benefit from a fair bit of work to turn into a carving axe, some way above my pay scale?
Chris152":1u36vkcz said:Is it normal for the hole in the axe head to narrow in all directions toward the centre of an axe head, with the top and bottom of the opening being wider?
Hmm. Didn't think of that when I carried on shaping last night...adrspach":29e1s4s4 said:When you fitting the shaft make it conical from half way down that it fits the bottom of the taper.
Chris152":9hgogmtf said:Hmm. Didn't think of that when I carried on shaping last night...adrspach":9hgogmtf said:When you fitting the shaft make it conical from half way down that it fits the bottom of the taper.
Top seems fine (the glued wedge went from about 1mm to 6mm and extends about 1/3 of the way down the head, couldn't ram it in any further):
The bottom, not so much!
Should I try to insert a wedge into that space? Is it just too dodgy like that to use for carving (I don't intend to be swinging it overhead)?
Overall tho, I'm really pleased with it - I shaped it to my hand and might make more changes as I get using it.
Chris152":1qld9vo5 said:Thanks Barto - I'll probably go with one, and maybe treat myself to a cheaper but decent folding knife for when I'm away. Preferably with a lock - I discovered the value of that the other evening, too.
What's a good angle to grind the bevel? I did both sides to 60 degrees but guess I could go to 45 or less?
