bugbear
AndyT":zihepbve said:Yes, big wet grindstones were used to sharpen hand tools.
You mean grind - sharpening comes later.
BugBear
bugbear":1zyl9ivs said:AndyT":1zyl9ivs said:Yes, big wet grindstones were used to sharpen hand tools.
BugBear
Jacob":35ufxvp2 said:https://www.youtube.com/watch?v=UbAo4RpM7oM&feature=youtu.be
Stropping isn't quite the same "honing" - it's purpose is to remove the wire edge and polish the bevel and the face which reduces friction behind the cutting edge.
You can strop with no abrasives - on your hand or on leather with a bit of spit. It polishes and removes the wire edge (if there is any left - it's mostly removed on the stone). It also livens up an edge that has been used. That's the traditional idea and it works. Autosol or similar helps but that's more polish than abrasive, though they merge into one another of course.bugbear":1i2ptbjx said:Jacob":1i2ptbjx said:https://www.youtube.com/watch?v=UbAo4RpM7oM&feature=youtu.be
It's simply a handy way of accessing finer abrasives than many common stones. Discussed with evidence and detail recently.
advice-on-which-leather-for-strop-t76314.html?hilit=stropping
BugBear
Jacob":1am1klwu said:You can strop with no abrasives - on your hand or on leather with a bit of spit.
CStanford":1f0tmwel said:Pussyfooting around with the burr might produce a marginally better edge. I guess under magnification it looks like a substantive difference. Magnification has a habit of doing that. Tiny bugs look like horrific monsters. Flies otherworldly. Unmeasurable scratches, the Marianas Trench. Maybe the key is to divest ourselves of our magnifying glasses.
And anyway, one doesn't really need one to admire these 18th/early 19th century beauties (yet again):
http://www.ronaldphillipsantiques.com/D ... oryID=1336
Lots of burls and other figured veneers and figured solid woods. How in the world did they manage to pull it off? Well, because they were able to. And in commercially feasible timeframes it appears as well.
The sharpening wonks and gurus don't seem to have an explanation for it other than to assume that they cried, cursed, and wailed the whole way through. I don't buy it. Not for one second. It's hard to argue with work that went out the door. Acres of it. To a very high standard.
CStanford":7rlkeh8s said:Maybe an oilstone and a strop work. They used to, apparently.
Something happened about 1990 or a bit later, when sharpening suddenly became very difficult for a lot of people.CStanford":qasgxsio said:.... Maybe an oilstone and a strop work. They used to, apparently. Did the Earth's magnetic field change and somehow make this no longer so?
Jacob":3qnqcxbq said:And yes an oilstone and a strop do work.
bugbear":9xxdh3qt said:Jacob":9xxdh3qt said:And yes an oilstone and a strop do work.
'swot I said. Consensus's all round!![]()
Especially if you use a decent oil stone or two; india-washita-arkansas oughta' be enough.
BugBear
CStanford":32p490vm said:bugbear":32p490vm said:Jacob":32p490vm said:And yes an oilstone and a strop do work.
BugBear
I usually only use the Black Ark on chisels FWIW. I'm babying a set of Marples straight firmers that I'd like to last the rest of my 'career' as it were. I've come to love those chisels.
I'm confused about what you use in your shop. Are you an oilstone man?
phil.p":3enjw72z said:Cheap for those with patience? I picked up a very nice extremely fine oilstone last week for a quid. The fine Norton at Axi is nearly £30. :shock:
