Farmer Giles
The biggest tool in the box
I have installed a 100mm solid pipe ducting system with a dual motor extractor and need to buy some flexible hoses for fixed and mobile machines.
For 100mm fixed machines I had some grey spiral flexible pipe with the kit so that was a no-brainer.
For 63mm fixed machines I have some 63mm reducers and need to buy the flexible pipe.
I also have a bag of second hand flip top waste gates that have 63mm cuff in and a 50mm socket out which I think may be perfect for mobile tools like routers with the appropriate reducer from 50mm to the tool and a short length of 50mm solid pipe to fit in the waste gate.
I intend to dot a couple of these above where I use these machines so there is less of that annoying pipe drag across bench edges.
So before I buy some 63 and 50mm PU spiral flexible ducting hoses, is there a standard used in workshops other than this that is better suited?
Andy
Andy
