Which cheap Pillar Drill
Creeky
29 Dec 2009
Bedfordshire
Hi all!,
Right, be gentle - first post.....
As Xmas has past I thought I would get a new pillar drill as my bench press is an very cheap one and jams every time I drill a hole! I have not got much of a budget £150-£170 max. I understand this will not get the best quality but really can't afford any more, plus it will only have occasional use.
I have come across these two:
Axminster AWFSRD550 Price £177
Or
Draper GD16/16CF Sale price £157 at Tooled Up
The Axminster does have better specs, so is that the on e to go for and does anyone have any experience of this?
Had a quick search for a second hand drill on ebay with nothing much in my price range.
Thanks in advance
Creeky[/url]
Hello Creeky
Welcome to the forum.
With that kind of budget you can get a Top-Quality drill press, it's just that it won't be new. Last year I bought a beautiful Meddings, c1963. I had already had new bearings and I replaced the switch for an NVR and filled the holes drilled into the table. I also gave it a paint job.
The drill cost me 160, which was a bit TT TBH, and I spent a tenner on a switch and another on some paint.
I now have a fantastic machine. The only thing I miss about my NuTools is the rack & pinion table, this is a dead lift. A bit of a pain, but I can live with it for the general accuracy.
I admit that it does require a bit of patience for the right machine to come along, though.
Steve
I have the Draper machine and bought it second hand on E-bay for £70. It is a good machine but could occasionally do with a little more power. HTH. :wink:
Thanks for the reply, when have you had problems with the power? I take it you were drilling big holes? Or does it just jam if I were to abuse it :)
Thanks again
Dan
Steve,
I must apologize, as I completely missed your post for some reason.
I agree with your opinion, It would be best if I took that root, as I have done the same with the Mellor Lathe I purchased a few months ago. Trouble is most of the good machines have 3 phase, which I do not. I could change the motor to single phase if I can get within budget.
I have seen a Startrite on the bay so will look in to the cost of a decent motor.
Good idea though, Thanks
Creeky
Check etd-trading on ebay, not much currently listed but I bought a motor from them for the second hand pillar drill I got from ebay.
Well Creeky, it was only when I have been drilling metal or using very large diameter bits. I can't fault the machine otherwise.
Thanks to both of you. I think I like the idea of buying secondhand now. will check out ebay for the motor, Cheers.
Keep up the good work, you guys are very helpful. Everytime I try to reply to one post, another one pops up. Cheers!
Creeky
I bought a Clarke 16 speed floor standing Metalworker from Tool Mart over 25 years ago. Rack and pinion cast iron table, that is still going strong. I use it with sanding drums that probably does the bearings no good, as well as the Wagner Safety planer. No problems. We get through at least one Axminster drill a year at school. Motors, rack and pinion, new handles.
Go for a used bargain. I got my single phase Fobco Star drill off Ebay for £50. A rock solid piece of old British engineering, The only downside with the purchase is that the machine needed a good clean.
Be aware that a decent drill is heavy - mine is a 2 person lift!
Misterfish
Thanks Misterfish, Think you guys are right, have found a couple now that I am interested in.
I will probably need to pick this thing up. are they easy to disemble? I have an estate car, so would like to take the head and foot off so it will fit in the boot, or is this a silly idea?!
I bought the cheap Power Craft one from Aldi, about 30 quid. I think its fantastic, drills 90 degrees dead on. Bought a set of Forstner drills on Ebay and cut all the rebates for the two mortice locks I fit on the garage doors. The stuff I've done in the garage with that pillar drill in the last month is amasing. I made 2 sanding tables and bought a set of sanding drums of Ebay, half inch up to 2 inch and use them to sand my scroll saw experiments, they are spot on. If it only last another week I've had my money out of it.
Mick.
Thanks Tenko,
Just one more question:
Steve (or anyone else that has and old meddings, startrite): Do you know whats involved in removing the head and foot from the drill? Are they just bolted to the pillar?
Yes. The casting is machined to be a good fit and then a couple of bolts clamp it up into the pillar. All very simple and straightforward, if a little heavy.
S
