RobC
Turners Retreat and Oakenden gets my vote
Random Orbital Bob":2e6xkfcp said:On the subject of tools, has anyone used the Sorby fluted slim parting tool? It's a 2mm width but more importantly has a fluted underside so the cutting tip has two points. It claims to leave a very fine surface by sheer cutting leaving little sanding but I'd be interested in hearing from a non manufacturers marketing dept source ie real life.
Random Orbital Bob":15cmu6zq said:Ah OK Mick, thanks for that......looks like I'm a sucker for their marketing! I hadn't come across it before and coupled with the description in the catalogue, I figured it was a recent innovation. I think I might take Bill up on his borrow and try offer before buying as they're not cheap.
Mark Hancock":vgrkdnzp said:Rather than going for the fluted slim parting tool you can achieve the same result by sharpening any thin parting tool up to 3mm 1/8" wide the way Tormek suggest. You simply place the parting tool on it's side flat on the grinder tool rest perpendicular to the wheel. This sharpens the front cutting edge and at the same time creates scraper edges to the bevels. In use you reduce the diameter of the wood with the front cutting edge and at the same time angle the tool to scrape the face you want clean.
