D J Builder
Recently I had to make some very large door did not have any clamps big enough. So I used 45 x 95mm timbers on bench fitted wooden block to one end then used old fashion floor board clamps to clamp frames, worked well.
I usually use a length of 2x3 with a pair of blocks screwed about the right distance apart and a wedge or pair of wedges driven between one block and the work piece.
same principle but without the floor board clamps.
