A
Anonymous
Guest
Hello folks -
I'm in the process of building a snare drum. Essentially it's just a wooden cylinder, 14" diameter X 6.5" deep, of maple (it's a Keller shell, if that means anything to anyone here).
After the initial shell preparation, as detailed in my previous post entitled "Finishing information from FVF drums", I applied a purple Liberon water-based dye. I slopped too much dye on, and it dried rather patchily. So, I tried to even it up a little, by (a) sanding the heavier patches lightly with 600-grit wet/dry paper, used dry, and (b) adding more dye. Oops. Not a good idea. It's a learning process.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The upshot is, the shell looks worse than it did, IMO. Alas, my digital camera is in for repair so I can't take a pic to show you.
I've two choices. The easy option is to buy a wrap, readily available from loads of drum wrap companies in the States, but I'd like to use this project as a sort of apprentice piece, if you like. I'd like to practice the lacquering/polishing process. I'll make my mistakes now, and not make them next time.
The other option is to disguise the poor dyeing, and this is where maybe Terry could help. Allow me to run this idea by you.
I've ordered a clear, water-based, gloss acrylic lacquer. The dye, too, is water-based. I'm not too worried now about showing the grain in the wood. If I were to add a little dye to the lacquer, to "darken down" the finish, would it affect the lacquer adversely? If it won't, I could still go through the rest of the finishing process, for practice, if nothing else.
Thoughts, anyone?
Stephen
Thoughts, anyone?
Stephen
