Whats that then ;-)
whatknot
29 Jul 2017
Cornwall UK
Picked this up on spec earlier
I now know what it is but does anyone else ;-)
It had me scratching my head for a while
    89.7 KB
    139.2 KB
    120.5 KB
    57.6 KB
    122.4 KB
I've not looked it up, and not seen one before, but I think it's the equivalent of an Eclipse no 39.
You are quite correct sir
A Stanley GF-H1-A
I had never seen one before today
Should anyone have any instructions for same I wouldn't mind a copy
Is there a readable patent number? I can't see it on Datamp, but Google Patents is pretty good on the more modern stuff.
No sadly not, there is no patent stamped on it at all that part of the label is blank
I can't see why your system is reporting an insecure connection.
You could try searching for the Carter-Stanley catalogue at archive.org yourself, then looking at page 44.
The gist of it seems to be that you can put a mounted stone, on an arbor, in your router then put the bit into the holder and carefully slide one base across the other until they touch. Presumably having set all the angle adjustments first.
Or else, if you have a Stanley shaper, with a big cast iron table, you use that to spin the stone and slide the cutter up to it, mounted in the fixture.
Good luck! And good eye protection too. :)
You sometimes get a false negative by security software, but its not worth ignoring just in case
I did find a not very clear instruction sheet which will do
    277.1 KB
