deserter":3iqa1l20 said:If your not worried about a hole through the middle a hole saw would work
Karl":2mnkk6qj said:Use a router and trammel bar to make the initial 200mm template, then use a router and bearing guided cutter to make future copies - using double sided tape to stick the template to the workpiece.
Karl
Tony Spear":3kzn9cya said:deserter":3kzn9cya said:If your not worried about a hole through the middle a hole saw would work
A 200mm. hole saw? Now that I'd like to see!
I'd also like to see a windchime with 200 x 25 mm discs!
