Wuffles":10o9pc6b said:I've emailed Silverline to see if they can make a clone of it that breaks as you remove it from the packaging. The race is on.
rxh":34x5ciax said:Thanks novocaine. After reading your post I showed the tool to a welding engineer who identified it immediately as a gauge for checking weld dimensions. Apparently, in Europe fillet welds are specified by the thickness – dimension “a” (measured in mm), whereas in the US they are specified by the leg length – dimension “l.l.” (measured in inches). The scales allow conversion between “a” and “l.l.”. The sizes of fillet welds can be checked by offering up the corners of the gauge. The sharp corners can be used to check the angle between two pieces prepared for butt welding, which should be typically 60 degrees but no less than 50 degrees. So the mystery is solved – thanks to all for your replies.
