Sounds fine. The voltage rating of the replacement that you found also looks ok.It's a 40w unit, photos of board attached too. The component is on the input side of the PCB which was a point you raised earlier about it's purpose.
I have to dissapoint you terribly by reporting that the reason the bits of copper are separated how they are is that I was prying with a screwdriver to see how bad the corrosion underneath had penetrated.I think that - as others have already said - this is a common-mode choke intended to reduce the amount of interference caused by the circuit, which would otherwise generate a lot.
Looking at the photo, I think that there as been a catastrophic event causing the winding to vaporize between the two points I've highlighted in red.
I think that the windings are flat because of the fact that these devices operate at frequencies where the 'skin effect' operates https://www.arrow.com/en/research-and-events/articles/the-skinny-on-the-skin-effect
At the sort of frequencies that these switching power supplies operate at, the skin depth in copper is only about 0.2mm.
If you look at the example diagram posted above, a broken winding will cut off power to the whole circuit. You have to ask yourself:
1) What caused this, and why didn't a fuse blow instead?
2) What other devices got damaged when this happened?
I'd be trying to draw a circuit diagram, by inspecting the board, and do some basic tests on the other components too. But I'd second the suggestion that it would be safer and simpler to replace the whole module.
I think that the 'catastrophic event was 'bloke with screwdriver' then !I have to dissapoint you terribly by reporting that the reason the bits of copper are separated how they are is that I was prying with a screwdriver to see how bad the corrosion underneath had penetrated.
Nothing got damaged when it stopped working, I just went up to the shed one day and the lights on the machine was off. It had been running 24/7 for about 2 years at this point in a shed environment (although it's fairly insulated it's not the same as being indoors).
As you rightly say, replacement is more sensible, I just didn't like the idea of throwing something away if it was repairable, particularly as it had been working so well for so long.
