Dibs-h
Direct comparison:
Many thanks Keith and Fitzroy, just as I thought but I suppose clever marketing at a time when were all looking to save money,,as you say it should not be allowed.They are an absolute con, It is nothing more than a wall mounted hairdryer & made from flimsy plastic. I wonder how long it will be before one burns a house down?
You would be better off with a 250 watt infra red poultry lamp. Half the running cost & warms what the light hits.
I just looked up single slice toasters. Found one at $65. When a normal two slice is $14.. I guess it's supply an$ demand. I wonder if you just disabled one side of te toaster. $14 and a set of wire cutters. Lol.I often stand waiting for my single bit of bread to toast wishing that the 2 slot toaster had a switch to turn off the unused 350-400 watts elements that are heating the air while I wait. How about a selector switch on low cost toasters to save? Every little bit helps.
Just incase you dont know a 400w toaster element uses 400w per hour. So if your toasting (or not toasting as the slots empty) for 5 mins, you will be wasting 33.3 watts. Average toast consumption per day for a "normal" person, I would think would be 3 single slices, per week that equates to 233.3 watts wasted, thats 12.13 Kw per year. The average cost per Kwh today is 33p. So wasted energy from toaster would cost £4.29 per year per person, using a dual toaster to cook 3 individual slices throughout the day.I often stand waiting for my single bit of bread to toast wishing that the 2 slot toaster had a switch to turn off the unused 350-400 watts elements that are heating the air while I wait. How about a selector switch on low cost toasters to save? Every little bit helps.
Putting it another way, those 33 watts wasted are the same as leaving 3 (100watt equiv) 11 watt LED lights on in empty rooms for 1 hour. I might be unusually tight but I would always turn those offJust incase you dont know a 400w toaster element uses 400w per hour. So if your toasting (or not toasting as the slots empty) for 5 mins, you will be wasting 33.3 watts.
So that's the answer then - live on toast?Just incase you dont know a 400w toaster element uses 400w per hour. So if your toasting (or not toasting as the slots empty) for 5 mins, you will be wasting 33.3 watts. Average toast consumption per day for a "normal" person, I would think would be 3 single slices, per week that equates to 233.3 watts wasted, thats 12.13 Kw per year. The average cost per Kwh today is 33p. So wasted energy from toaster would cost £4.29 per year per person, using a dual toaster to cook 3 individual slices throughout the day.
kW and kWh are not interchangeable. A toaster can't use 400w per hour, 400w is a measurement of instantaneous power.Just incase you dont know a 400w toaster element uses 400w per hour. So if your toasting (or not toasting as the slots empty) for 5 mins, you will be wasting 33.3 watts. Average toast consumption per day for a "normal" person, I would think would be 3 single slices, per week that equates to 233.3 watts wasted, thats 12.13 Kw per year. The average cost per Kwh today is 33p. So wasted energy from toaster would cost £4.29 per year per person, using a dual toaster to cook 3 individual slices throughout the day.
This is where you can save by having your house wired for efficiency and have multiple circuits whereby some can be on timers so switch off overnight, you could also include a power meter so you can see the loads.idle consumption of small electronics and appliances
I splashed out on a Flir C5 thermal camera recently thanks to ebay. I'll sell it on in a year or two.
Nothing beats being able to see the heat and the cold for focussing attention.
This was funny - I'll bet the old Sky router (front right) "wastes" a lot more energy than the new "FritzBox" (back left).
Mind, this just confirms what we knew already since the cat always chooses to sit on the sky box, never the Fritz !
Next to measure the Watts and multiply by 24 x 365 to work out how much it costs to heat a cat.
It was interesting to observe that the two power / energy metering plugs that I bought to look at the consumption of appliances consume a few Watts themselves. More that any of our USB chargers certainly. I have unplugged those rather than leaving them in doing long term recording of power use.This is where you can save by having your house wired for efficiency and have multiple circuits whereby some can be on timers so switch off overnight, you could also include a power meter so you can see the loads.
Not to sound pedantic but there is a direct correlation between the wattage of an item of equipment and the resulting KWh value that we are interested in. The KWh value is derived by multiplying the wattage of equipment by an hour, hence a 400w rated appliance will use in one hour: 0.4 KWh. So divide that by 60 to get KWh per minute (0.000111166889 KWh) x 5 minuites = 0.00055583444 Kwh = 6.67wkW and kWh are not interchangeable. A toaster can't use 400w per hour, 400w is a measurement of instantaneous power.
But then what do I know? I must eat 8 or 9 slices of toast per week.
Yeah looks like my calculations were out but you get what I mean
