TrimTheKing
So, I was changing the blade in my bandsaw last night and after fitting it and slightly tensioning I was spinning the upper wheel by hand to centre the blade. All good.
Then, the phone rings so I reach over to the bench to grab it, can't quite reach comfortably so stretch, but still keep spinning that wheel :roll: and guess what, on the final stretch my finger slips off the rim of the wheel and though one of the holes in the casting and gets nipped between the wheel and the tensioning guide.
Natural reaction was to whip my finger out quicksmart and on inspection it appeared to have suffered a very small nick on my fingertip with a tiny speck of blood. On further investigation (stretching the skin to make sure it looked okay) the blood gates opened and the pain came.
Jammed my finger over the skin and pressed hard while going to the sink and running under cold water for a couple of mins but the blood would just not stop. Cut is only about 8mm long but about 5mm deep and would not stop bleeding. Eventually I managed to apply enough pressure for long enough for it to stop flooding long enough for me to get a plaster on there nice and tight to pull the two sides together.
All seems to be sealed up now, still got a plaster on there to stop it catching but I feel very fortunate it wasn't worse! Lesson learned by me, always concentrate when playing around with your power tools, even if they are not switched on.....No phone call is worth a finger!
Mark
Mark
