Well its a while since I have managed to update on progress with the rack. Last time I posted I had just drilled all the bits of wood for the movable welly supports and for the fixed parts and had produced lots of bits of beech dowel.
So having carefully measured out the holes in the frame for the dowel it was time to drill them.
I then mitred the corners of the frame on the table saw. I have failed to take any photos of this for some reason. I used my little digital angle box to ensure the blade was exactly at 45 degrees. I then set up my biscuit cutter bit in the router table to add a biscuit into each of the mitres to give them a bit of strength. The picture looks very odd as it makes the mitre look stepped which it isn't, but its the only one I have got.
And this it the result.
I then set about cutting the wider supports to go behind the moving parts of the rack. These serve several purposes. The first is to keep the pieces at 90 degrees when open. Secondly to ensure that the pieces are flush when shut. Thirdly to stop the fixed pieces from rotating and finally to stiffen the whole thing up a bit.
They are about 52cm wide and 10 cm high.
Next I wanted to put some keyhole supports in the top brace so could hang the whole thing on a couple of screws in the wall. I was going to use my little Katsu router which doesn't have a plunge base, so I started by drilling some holes.
This was the router bit I was going to use.
I then clamped in place a square as a fence and a stop with a couple of odd bits of wood.
And it worked like this.
I then set about drilling the braces so I could screw them in. I could probably just have screwed straight in, but I was being cautious having spent so much time on it so far.
Then came the fun bit of screwing the braces in the correct places. Too low and the supports won't open fully, too high and the supports will slope down. In the end I resorted to a large square bit of wood and lots of clamps.
And this is what is looked like from behind, with the moveable parts horizontal and the fixed parts vertical.
This shows the top brace screwed in with the keyholes in it to hang it on the wall.
And finishing off the final brace at the bottom.
Now is where I confess I made some mistakes with all of this. Firstly I screwed the fixed uprights to the braces with the uprights vertical and the supports horizontal. I found out that was a bad idea, as when closing some of the supports the gaps were not perfect and they jammed. I therefore unscrewed them all ensured all elements were vertical and re-screwed them which much improved the situation.
Secondly do you remember that I put a bit of card between each of the uprights when marking out the rails to ensure they could move, well it wasn't thick enough. Luckly I discovered it before gluing the frame together. I had to run all the fixed and moveable parts through the tablesaw to take off about 3mm so they could open and close.
Anyway here is a photo of it with all the supports folded down, but all the ends needing staining from where I had cut them off. Despite my best attempt at precision they didn't all open to exactly 90 degrees, but close enough to support wellies!
And this is what it looked like shut.
Then it was on to a trial fit in the porch.
Now the thing that has been delaying me recently is that the rest of the porch needed decorating. Its not large, but it took me a while. So here it is finally finished.
And with the families wellies on it.
So if I were doing it again, and I am not planning to, I think I might consider using continuous bits of dowel for the whole width and possibly metal rod to ensure a straighter finish. Overall though it looks much smarter than all the wellies on the floor previously and is not bad for some scrap wood that other people were getting rid of. I hope it has been of some interest to follow sporadically.
Now it is onto making some metal hoops to try and keep the dog out of the flower beds!
Best wishes,
Mark
