Munty Scruntfundle
I'm sure there are a few of you out there that remember the humble Weeble. Horrible little plastic potato faced things that "wobble but won't fall down!"
My sisters asked if I could make a couple out of wood, plastic really isn't her thing.
I've made a couple now, but no matter how I think about this there is no perfect way to produce them on a basic lathe. For the sake of this post I'll call them eggs, with a top and a bottom half.
If I turn the top as you would a goblet, so the inside is hollow to remove mass, it's difficult to finish the point. Turned the other way around you can get a lovely top but you can't hollow it.
If you turn the bottom as a goblet you can drill through it for a metal weight and glue the top for finishing, (solving part of step 1) but it's difficult finishing the bottom. If you turn the bottom the other way around you get a lovely bottom, but you can't glue the top on for finishing, and you get a through hole.
Has anyone made any of these, if so what was your work flow?
Thanks.
Thanks.
