RossJarvis":q8y68hy5 said:That's what I was assuming. Having read about possible issues where thinner irons aren't "fully supported"
I was just wondering if the user found the plane worked well with this type of support only. I think Bugbear has now pointed out that the important element is support near the cutting edge.
AndyT":14b50knp said:Brilliant work.
There's nothing like the satisfaction of solving all those practical problems and getting through to a very smart end product.
I especially like the dovetailed toe on the handle
and the neatly spaced hand filing on the blade-holding screw.
My Italian is not up to reading the text, but looking at the pictures, do I see signs of the delicate kiss of the arc welder ?
I had always assumed that all this dovetailing and riveting was because welding would distort the plane too much - if not, could a fully welded construction work ? I assume not, as noone seems to try it.
Richard T":3hzwold1 said:Adjustable frogs, when moved forwards to tighten the mouth, leave the iron dangling unsupported by the sole. This sole and frog are solid McSolid.
The iron is supported under the pressure of the lever cap at the business end and where the screw screws down. A very neat idea. The frog rivets in the sole support both.
CC - indeed, a very lucky scrub plane.
Pekka Huhta":wqyqolke said:Brilliant plane, congratulations. Lovely work and brilliant ideas on all of the small details.
I happened to notice the lathe you have there: all the details are not visible, but it looks very much like that one: http://www.sihistin.fi/en/woodwork/lathe.html . Or did I see it right?
RossJarvis":1h9k618v said:Tell your friend and yourself that we are all mightily impressed (and I'm a little jealous).
Please can we see the next one in fuchsia to compare :lol:
Jacob":13c7qh26 said:PS very easy to sharpen freehand, no great precision or accuracy is called for. I really wouldn't bother struggling with a jig it will just make it more difficult. No flattening required, back bevel OK to make it easier.
Very nice plane BTW!
MIGNAL":wxc6775k said:The first mm or so of that blade was seriously hard, until I got back to what felt like normal carbon steel. It's a very good blade.
Andrea":3arssgai said:bugbear":3arssgai said:I would recommend checking out my page on flattening - I sincerely believe that rubbing a plane on sandpaper on a flat surface is not the quickest or most accurate way to flatten a sole.
Thank you for the links. I'm very intrigued by scraping metals, but I have never experienced it.
However I think that a scrub plane does not need a great accuracy in surface flattness.
bugbear":37nl9e3m said:Oh, that's very neatly done!
