AJB Temple
Finely figured
I need to find a way of returning water to a pond from a filter. This needs to fit in aesthetically with a Japanese style garden.
The water will fall by gravity, from a height of about 30 or 40 cm (I can make this pretty much anything within reason by raising the filter outlet) and will then have to cross another pond that is about a metre wide (but 20 metres long) before reaching the required pond about 4 to 5 metres away.
The pond holds 28,000 litres and the water is being turned round at a rate of roughly 12,000 litres an hour. The outlet is gravity fed and hence is ejecting about 3 litres a second. The conventional method is to drop this via a short pipe straight back into the pond. I can't do that because the narrow pond is in the way.
I could run it underground in a conventional way or I could make a stone rill and run it above ground as a narrow stream. The direct route though is directly across the narrow pond and I am visualising a wide timber gutter (which you do see in Japan). The question is how would you design and make a timber gutter that will not leak (as if it does I am gradually stripping water out of the pond) and will handle this flow rate. It must look good - not a bodge up or twee. I can't line it with lead or copper as this is toxic for fish (there will be various fish including Koi).
One solution is a very wide bamboo channel. I have not yet found suitable bamboo. I am fine with rectangular design.
