Hi @Glitch. Another question for you, if I may.
I'm getting round to doing the door and was wondering whether you knew the dimensions of the timber your joiner used for the door (perhaps still exposed on the inside?). It all seems very deliberate because the bottom ledge is markedly wider than the other bits, and middle ledge is wider than braces, etc.
So rather than doing a ton of research on what should be done, I was wondering if I could take a cheeky shortcut and just get the dimensions (thickness and width) of the ledges, braces and vertical bits from you please?
