WANEY EDGE ON A TABLE SAW
Lazurus
22 Sep 2017
Norfolk Broads
A friend has asked me to rip some waney edged ash boards for him. Is there a "correct" way of doing these. They do not need the waney edge but I can forsee problems running along the fence?
Screw a long offcut to give you the first straight edge or use a track saw.
If there are several to do, your friend investing in a cheap tracksaw wouldn't be a bad idea at all, particularly if he needs it from time to time. It is one of my most useful tools.
No idea about correct, but you have lots of options:
Screw a flat reference board to run along the fence.
Attach to a sled with a straight edge. You can use toggle clamps or screws for this.
Plane one edge flat and run it against the fence. This is what I do, and hand planing a waney edge is pretty quick and fun!
Now, I don't recommend it at all and I know some people here will absolutely cringe but I've always done boards that are circa an inch or so thick with a really waney edge just freehand through the saw following a chalk line carefully. On thicker boards, I'll drop the surface planer infeed table for a heavy cut and just knock off the high spots down quickly by pushing and pulling the timber back and forth over the cutterhead without lifting it off the table until a full flat pass is achieved, again that's a pretty sketchy way of doing it and I don't really recommend it for the faint of heart.
Hand-held circular saw and a straight batten of wood clamped down is the simplest and arguably safest way to rip it off but is rather time-consuming if you've got a lot to do.
Yep, done this plenty of times, I do like a chalk line, good old days, I sometimes knock a wedge in to stop binding.
