Wall Clock (loads of pics)
Just me putting in my two-pennorth, cut your circles whichever way that suits you, but cut a spare and keep it then you can trim on your router table with a bearing guided pattern cutter next time you want one, I have about twenty-five circle blanks for this purpose, so much easier.
Derek.
I have managed to make a carriage for the next operation on the router table, its for cutting the slots for some splines
The slots ready for the splines, they are only small but will add a little more strength and some decoration.
I am going to use Sapele for the splines, I ripped some long strips on the table saw the cut to length on the chop saw, time to apply the glue
I placed the in a sash clamp just push them in as far as they could go, this pic also shows the reverse of the clock.
A close up of the inserted spline albeit a little blurred, have to wait for the glue to dry before i can start trimming them off, that'll be in the moring hopefully.
That jig looks like a good idea, I've done something similar in the past for mitres. Those splines should prevent the mitres from ever opening up.
regards
Brian
Good-looking jig, Martin. :)
Although I'm sure your work won't suffer from this, splines are generally cut and fitted so that the grain runs in the opposite direction to the segments. I reckon you've got enough overlapping fibres there anyway, so I wouldn't worry about it this time. :wink:
There isn't a lot of choice Olly, or is there? if I were to have the grain running in the opposite direction would it not split in this instance :? or am I missing something.
The jig is quite simple, a few bits of scrap cut at the right angles and glued in the appropriate positions.
The glue is dry, now to trim off the excess, I had to be careful here as the Sapele tended to split if I took too much off so I just nibbled it off little by little
Next I rounded over the outside edge
After a good sanding I applied a coat of Danish Oil
I love the way the Sapele looks (if I had a decent camera instead of my mobile phone you'd be able to see also :oops: )
It almost looks like the drawing :D
Thats all for about 5 or 6 days as I have to do a block of 12 Hour night shifts :cry:
motownmartin":1xc96ctp said:
Thanks chaps
See if you can help me choose which numerals to use, I like the smaller ones
These are the hands I shall use
I like the darker ones :lol:
the others look a bit too much like bling , too bright for the timber :?
just my opinion :wink:
the oters look a bit too much like bling , too bright for the timber :?
agreed
Third one down, that's my vote. =D> =D> =D> =D>
That's a handsome clock, not too fancy, not too plain. Just right. :lol:
John. B
just throwing a cat into the works and a spanner amongst the pigeons , have you considered not using numerals at all ? or maybe just at 12 , 3 ,6, and 9.
most people can tell the time just from the position of the hands and the clock looks so good that it might be a less is more type situation
