sometimewoodworker
Well I've been using both a slightly skewed rip fence and the mitre fence in its slot for the last 40+ years, so my experience disagrees with what you claim.Steve Maskery":35yyc284 said:sometimewoodworker":35yyc284 said:Also For the Inca bandsaw another way that you adjust for blade drift is by changing the angle of the fence relative to the blade, the rip fence is designed to be adjustable to some degree.
No, no, no. I'm sorry but this is wrong.
It is certainly true that you CAN compensate for drift by skewing the fence, but it is a very poor solution, because it makes the mitre slot unuseable. OK if your table doesn't have a mitre slot then I accept that it is OK to do this, it makes no difference.
But if you have a BS with a mitre slot and want to use it, then the blade MUST be tracked to be parallel to the mitre slot AS WELL AS the rip fence, and the only way you can do this is to have the rip fence parallel to the mitre slot (which is what those adjusting bolts are for!) and then track the blade to both.
And yes the top wheel of course is adjustable in angle. But THERE IS NO WAY to use that to change blade drift. The only thing that does is to get the blade to track correctly over the edge of the tyre or incorrectly on the tyre. Any adjustments to the wheel angle change the positioning of the blade on the tyre.
As I have said what you say applies to the majority of bandsaws. It does not however apply to the Inca.
