Hello everyone,
I bought a ags 10 saw the other day here in Germany. It is in pretty good shape apart from the cast bracket the rivin knife mounts onto (It is the riving knife that is in the parallelogram style). It is a newer modell being from 78(if I read the Machine Number correctly). The bracket for the riving knife which mounts to the saw arbor is broken into two pieces. I would like to fix it and for that I have to get it off the arbor which turns out to be harder than I tought it would be. I pulled the pulley off (with quite a bit of trouble) only to realize that there is some sort of lockin ring which is secured on the spindle with two locking screws. The whole locking ring sits in the hole for the bearings (see pictures). I just do not get how I would reach the screws without drilling a hole into the casing and have no idea how they assembled it like that. I tried pulling of the saw flange but it didn't go anywhere and I am afraid to damage something if I use much more force. I also tried heating it a bit, didn't help either. Any tips on how to get the locking ring off?
thanks in advance,
Lukas
thanks in advance,
Lukas
