BorisTheBlade
Hello can anyone ID this lathe please? If anyone here has a manual I would be very grateful!
Thanks Vann. Do you have a manual? CheersYes it's a Wadkin RT woodlathe - made 12 machines after my own Wadkin RTA 380.
Cheers, Vann.
Thank you, I recently bought one in bits, the guy selling was "partway through a refurb". He said the motor works but he didn't have the know how or confidence to figure out which components (if any) need replacing so it sat for 5 years and now he's moving into a boat. So I could just put it together and hope for the best but would like to give it some TLC first and replace any parts that need it before using it properly.No manual (I'm not sure if they produced one).
It has a 6" swing. I think maximum length between centres is 36". Both head and tailstocks have 2MT tapers. The headstock also has 1 3/8" BSW thread. Speeds are 1500 and 3000 rpm.
About the only feature I can think of is the speed selector handle can be removed and becomes the spindle lock (unless you've munted it like I have mine).
Anything specific I can help you with?
Cheers, Vann.
I bought mine from a school about 300 miles away. I borrowed a van and dismantled the lathe outside the classroom, then lifted or rolled (on pipes) everything into the van by myself. Lifting the headstock off and back on was the heaviest (and hardest) - the bed was done using levers and blocks....unloading the other on my own was interesting...
Thanks, I really appreciate the help. Yes I made some funny noises carrying the headstock.I bought mine from a school about 300 miles away. I borrowed a van and dismantled the lathe outside the classroom, then lifted or rolled (on pipes) everything into the van by myself. Lifting the headstock off and back on was the heaviest (and hardest) - the bed was done using levers and blocks.
Here's the story of mine Wadkin Wood Lathes Hopefully you'll find something useful there. If you need more info, just ask.
Cheers, Vann.
Parts are, of course, like hens teeth for a machine that old (and mine is the newest of my six Wadkins). Be prepared to pay an arm and a leg for what you can pick up on eBay....Am just starting to look into parts I may need now so if they have a long lead time I can have them ready for when I start on the lathe...
IIRC I paid $250 NZD for mine ( ~£125)....and I now have a Wadkin lathe for the princely sum of £50...
Yes I once called Wadkin in Leicester about parts or refurb and they plucked some crazy numbers out of thin air. That's when I realised I have to buy old tools with all components it needs and any it doesn't have be able to fabricate themParts are, of course, like hens teeth for a machine that old (and mine is the newest of my six Wadkins). Be prepared to pay an arm and a leg for what you can pick up on eBay.
Wallace put up a restoration he did on an RTA Wadkin RT Lathe restoration but unfortunately most of his pictures have gone.
Cheers, Vann.
