nathandavies
OK i'll start with a disclaimer. Don't expect this to be regular or quick, depending on work this may take some time. If it's quick, it's either easier than i'm expecting or business is bad.
Pictures of the mean machine before starting
As you can see it's in a nice NHS type blue. I picked this up in a job lot of stuff. Every single nut and bolt and screw is/was seized. couple of broken bits, handle at back of column, and opening the motor casing found a broken fin, presumably this is why another fin has a nut and bolt through it to balance it.
The plan is for this to be a dedicated dado saw, as I already have another crosscut set up. Not sure what colour yet. Or whether to go original or pimped, we'll see.
Nathan
Nathan
