Wadkin ags 10 Lock Nut
Been out to the shed and taken a bunch of photos and measurements best I can of the nut from my AGS10 it’s an early model with the spindle housing integral to the swing arm.
From what I can tell the thread on the spindle is square, the nut definitely has a narrower root than crest.
Fitz
    1.1 MB
    1.4 MB
    1.2 MB
    1.4 MB
    379.8 KB
    213.8 KB
    268.6 KB
Fitz
Thank you for the pictures. This is exactly the same as my one. Not fully checked the measurements but looks right. I will ask to return it with few pictures of other square spindles for proof.
I think @Bingy man has a pint that’s not been buttoned down. I agree with the assessment that the threaded section of the spindle looks bent. Please check it out before committing another nut. I’d place a metal ruler against the threads (after a good wire brush) and with a light behind the ruler look for any gaps indicating it’s bent. Check again at 90 degrees to the first test.
Have to say it was @Distinterior that -1st noticed this , the op has checked it though and says it’s the camera angle if I recall.
Yeh I checked and it was straight to my plastic ruler. Never checked it with a proper rule though. John Mills (DoubleBoost on youtube) currently has it and seems pretty confident he can get a nut sorted.
Fitz
The drawing of the thread profile - if accurate - indicates a totally non-standard thread. My initial thought on seeing it was that it might be 'Stub' ACME but the included flank angle calulates to 36.8º whereas any ACME should be 29°. The drawing also indicates a 'pitch' of 2mm so If we assume that it is a Metric thread then a Trapizoidal form should have a 30º incl. angle.
One issue is that both ACME & Trapizoidal form threads are often 'Non-Standard' since they are often used for 'non-standard' applications. ie. the 'Standard' seldom persists - except as far as the thread angle is concerned.
Its definitely a square thread on the early machines.
The thread profile I drew is in the nut. The shaft has a square thread that is clear from the picture. The nut, from the best I can tell, does not have a totally square form.
I’m guessing, but I suspect that the form of the thread was created by hand grounding HSS, and the discrepancy in the nut is due to that. After all the inspectors I suspect would use a go-no go gauge and as long as it passed it was good to go! After all, they couldn’t see the thread form like you can in the spindle🤪
