h2ostartup
New member
Hello,
First posting, here it goes. Firstly I must say that the forum has been helpful in getting me this far. I recently thought to upgrade to an old classic and for several reasons I picked an Wadkin 10".
The saw was known not to run and the motor is out getting rewound, so I figured I have two weeks to sort out the sticky rise and fall issue. Mainly it makes a fair bit of moans and requires effort when within the last 1 1/2" of either rise or the fall. The worm gear and quadrant teeth are all present. After a clean and new lubricant still the same condition. Played around with the retaining strip and the three adjustments to no avail. Like I stated above since the motor will not be back for a few weeks I figured to get on with it and dis-assemble the saw to get to the rise and fall bits. I did observe that once the spindle assembly was off the rise and fall noise went away. In for a penny I continued with dis-assembling.
Everything went OK and this is where the forum has helped. Now I think I found a problem with the rise and fall screw bearing not being seating fully. I can only see that this would bring the front (wheel) forward to closer to the angle indicator, but its hard for me to understand if this is the cause. I'm nervous that this is in two pieces and that's the reason why its the way it is. The diagram shows that its one piece? Also is item 70 1/4" gas pip screw associated with setting the bearing, similar to a grub screw??
Firstly, I'm wondering the best approach to get this removed as the brass sleeve that's inside is floating with the gap. This is not a huge problem as I can get it back into the sleeve.
Does the piece get fully pressed into the space available? Lastly what's the best approach to press it back in as this piece fits into the trunnion with limited space and the press is dependent on the angle indicator, I think?
Any insight on the screw bearing it would be greatly appreciated.
Wes
Wes
