Versachuck jaw flinging woes
Lots of generalisations within the above answers. As this is the Wood Turning & Lathes section we should restrict our answers to wood turning chucks.
In case you were unaware, the current range of wood turning chucks are based on metal turning chucks.
In fact the very first Axminster precision chuck (1980?) was an off the shelf metal turning chuck. There’s very little difference between some of the Axminster wood turning chucks and those used on metal turning lathes.
Axminster (and probably others) noticed that some metal turning chucks had two part Jaws. Chuck or Base Jaws and bolt on Top Jaws. Axminster just had Top Jaws (they sometimes call them Accessory Jaws) made to suit wood turning applications.
Axminster make some longer carriers which means they may possibly protrude safely beyond the chuck body but until I check I don't know whether that is the case. The design may be that the jaws are mounted further out on the carriers so that the carriers have no need to protrude.
One chuck I owned had a (removable) roll pin to stop carrier 4 from being extended too far therefore the carriers had to be entered so that carrier 4 ends up in the right slot. Sorry can't remember which chuck.
I also had another chuck where the carriers were numbered wrong & had to be fitted in the order 1,3,4,2.
The other thing that is confusing for beginners is using different names for the same thing. Chuck jaws & carriers (Axminster's terminology & what I use) are two different items. Jaws are attached to the carriers by means of screws or bolts. The teeth on the underside of the carriers mesh with the scroll on the chuck to move them in & out.
If you have an unnumbered set of carriers, the front tooth on number one will be furthest forward with each front tooth being slightly further back than on the previous carrier.
I agree about confusing terms. Axminster and others frequently make up their own names instead of using more appropriate ones that have been around for over a hundred years. 🙄
The Scroll or Self Centering Chuck, on which many wood and metal turning chucks are based, was invented in 1840. The patent holder called the Chuck Jaws “Slides”. Within about ten years others had improved on the concept and in later patents the name changed to “Jaws”. There’s a very obvious reason for this. Each Jaw has several large “teeth” on the back that engage with the Scroll Wheel. Many also have rudimentary “teeth” on the front as well to grip the workpiece. I think it’s fair to say that since about 1850 most machinists have been calling them Jaws, Chuck Jaws or sometimes Jaw slides.
Wood turners, including some professionals have invented or repeated: “Carriers”, Carriages”, Travellers, “Sliders” and probably several others. None of which are exactly descriptive of the component.
One thing is for sure. Whether it’s a metal work Chuck or a wood turning Chuck, they are all *Four Jaw Scroll Chucks.
I have never seen a four Carrier or Traveller Chuck, have you?
*For metal working you can get scroll chucks in 2 Jaw, 3 Jaw, 4 Jaw and 6 Jaw. There may be others.
Not really, they’re both just engineering chucks. Many manufacturers make them.
All scroll chucks work the same - as the scroll wheel rotates the Jaws are moved in or out. Engineering chucks all seem to have enclosed scroll wheels and use pinions to rotate them. Some wood turnings chucks have exposed scroll wheels on which the chuck key rotates directly through a hole in the body.
The only other difference I’ve seen is that early Supernova Chucks worked in the opposite direction - righty loosey, lefty tighty.
They gave up on that a while back though and they tighten/loosen the same as all the others now.
Someone asked me the difference.
But folks can call them what they like. 🤣 😂 😅
Sorry, but I disagree. You will have a job to hold anything with what you are calling jaws.
As I said before, jaws are mounted on the carriers. By calling them jaws, even though Axminster now call them Accessory Mounting Jaws, you are misleading those that don't know into thinking their purpose is to hold wood.
No, that’s your interpretation. But you’re wrong anyway. I’ve held wooden dowel and other stuff in the Chuck Jaws.
Just one example, I’ve done this many times. Not just me either. I’ve seen more than a few people turning aluminium or brass using only the Chuck Jaws.
I just happened to look at the Axminster website. It looks like they’ve stopped calling the Chuck Jaws “carriers” now? 😮 😆
Understandable really, “SafetyCarrier” doesn’t have so much of a ring to it, does it?! 😊
Everyone I know calls the bit that hold the wood "jaws" and the bit that hold the jaws "carriers" or "slides". This makes perfect sense to me so I will continue to use the appropriate but (according to the pedants ;)) incorrect terminology!
But interestingly, and going back to the original question on jaws being flung out. The photo of the Axminster accessory jaw carriers show a red dot, which indicates the full safe extension beyond the chuck body when visible...
Everyone I know calls the bit that hold the wood "jaws" and the bit that hold the jaws "carriers" or "slides". This makes perfect sense to me so I will continue to use the appropriate but (according to Axminsters) incorrect terminology!
I’ve corrected that for you.
At the risk of adding fuel to the fire I think it all depends on whether the parts that engage with the scroll have shaped ends, which are clearly shaped to hold something, as in Vulcan's image. In this case I think they can happily be referred to as jaws. On some metal working lathe chucks this is not the case, and the separate jaws have to be bolted on to actually grip anything, in which case I think you can reasonably make the argument that they are not jaws but something else, carriers would seem as good a term as any.
On some metal working lathe chucks this is not the case, and the separate jaws have to be bolted on to actually grip anything.
I must admit I’ve not seen anything like this. I have scroll chucks and independent chucks and they all have teeth.
Before chucks were invented they sometimes used individual Jaws bolted to a face plate. This is a modern face plate and Jaws pictured below.
The method used for bar stock on engine lathes was to turn between centres, the workpiece rotated by a Lathe Dog engaged with a slot in a face plate. Still regarded by some as the most accurate way to turn a shaft.
I have a Taylor one where the jaws are bolted to "carriers" which are not themselves shaped. I have several other Taylors that have a more conventional design.
Also an 8 inch or thereabouts four jaw independent, make unknown, where the "carriers" sit well below the surface, and again jaws have to be bolted on to really do anything. Both were auction finds. In both cases I suspect the idea may have been that it is far quicker to change the jaws for inside or outside holding than to wind them out and put them back in the other way round as in more conventional designs. And of course you can make the detachable jaws whatever size or shape you want for specialist jobs.
I use dogs in that way quite often, very simple and easy to set up. Usually using the catch plate that comes with most lathes rather than a face plate as such.
I have done what I set out to do, which is make sure any beginner reading this thread doesn't fall into the trap of thinking that carriers & jaws are the same thing.
No. You seem to be trying to mislead beginners into using a term you use, rather than the correct terms used by reputable Chuck Manufacturers. All anyone needs to do is to visit a Chuck Manufacturers website pages.
Axminster: Jaws
Record Power:Jaws/Slides
Nova: Jaw Slides
OneWay: Base Jaws
Vicmarc: Backing Jaws
You’re not still searching the internet for a Four Carrier Chuck are you? :ROFLMAO:
