G S Haydon
- Joined
- 24 Apr 2013
- Messages
- 1,667
- Reaction score
- 223
Charles, of corse I do know that . I just wanted to try a 220 grit edge from my India. All I can say is a 220 India is not a useable edge.
CStanford":2v5bhdll said:CStanford":2v5bhdll said:PMVII does not get sharper than a quality piece of O1 tool steel. This may be the new marketing thrust, but it's bunk. And the longevity claims in multiples (two to three times as long) arch one's eyebrows as well. I can personally attest that this is not the case with the chisels. Edges last a little longer, yep they do. Sharper initially? No. I think a skilled cabinetmaker would be willing to take a PMVII chisel through one more dovetailed corner than he or she might an O1 chisel. .......
Just for the record, that is utter and total misinformation. Charles, you must really have an issue to post such cr@p. There are a number of assessments out, including a few by myself (under scientific rules) and the one referred to at the start of this thread. What testing have you done with a scientific focus (tests with replicatable methodology). Your one-time use of one chisel no doubt was so biased you only saw what you wanted to see.
Regards from Perth
Derek
'Under scientific rules...,' oh brother please. You must think the entire woodworking world other than you and the people who reflexively agree with you (the vast majority of whom are shopaholics or those who supply them) are total idiots.
The sad and unfortunate thing is the the tools are fine. They don't really need the hype. They're good tools. Lee Valley doesn't sell junk. But for some reason you think it's your job to overhype, oversell, and overexaggerate the performance of every new tool they put to market. They're always, in essence, blowing some other tool brand out of the water. Kaboom. Always. And almost always brands considered to be their 'competition.' Ye Olde foil du jour. It's ridiculous, and sad, and counterproductive in my opinion.
I'd be happy to own a set of PMVII chisels. They work fine. They are not Earth shatteringly fine, but they're fine. They cannot or could not be blamed for bad work. They have edges that outlasted the chisel I used for comparison, not by magnitudes but by a not necessarily insignificant amount depending on one's outlook. I do stand by the fact that they DO NOT get sharper. That's a bridge if not two or three too far. They just don't. If that was one of the production goals then it has not been achieved.
Peel yourself off the ceiling and come back down to the ground.
OK perhaps substitute "medium fine" for 250. I'm a bit vague about grit sizes unless it's printed on the box. A double sided coarse/medium stone was a common beginners spec - any finer being wasted on a novice.G S Haydon":1c5waby6 said:Charles, of corse I do know that . I just wanted to try a 220 grit edge from my India. All I can say is a 220 India is not a useable edge.
phil.p":1l3tk0xn said:I suspect this is the sort of answer the OP was interested in and will probably thank you for it.
jimi43":1h08ucza said:phil.p":1h08ucza said:I suspect this is the sort of answer the OP was interested in and will probably thank you for it.
If indeed the OP is actually around as the thread is well over a year old and was resurrected recently to provide our very own "Speaker's Corner"....which was nice! :mrgreen:
Jacob":2ruy7ivs said:There is a lot of misunderstanding around - take that recent spat about "camber" - it seemed to me that a few people had no idea how or why it works (i.e. crudely - that a deeper/narrower scoop takes more material away for same effort) so surely it is helpful to talk about these things whether or not you agree with anything in the end.
You still haven't got it BB and you are still making it a personal issue. You really do have a sorry chip on your sad little shoulder!bugbear":3ky5rbpn said:Jacob":3ky5rbpn said:There is a lot of misunderstanding around - take that recent spat about "camber" - it seemed to me that a few people had no idea how or why it works (i.e. crudely - that a deeper/narrower scoop takes more material away for same effort) so surely it is helpful to talk about these things whether or not you agree with anything in the end.
Another superb strawman! You made a very specific - even mathematical - claim about optimal blade
shapes, which was easily proved to be quite simply wrong; the practice was wrong, even the maths was wrong.
There was no discussion about the mechanism or action of camber in general,
although I did note your attempts to start various discussions, as a distraction from your error - the old "Butler Swerve".
BugBear
Jacob":1ecuf804 said:You still haven't got it BB and you are still making it a personal issue. You really do have a sorry chip on your sad little shoulder!bugbear":1ecuf804 said:Jacob":1ecuf804 said:There is a lot of misunderstanding around - take that recent spat about "camber" - it seemed to me that a few people had no idea how or why it works (i.e. crudely - that a deeper/narrower scoop takes more material away for same effort) so surely it is helpful to talk about these things whether or not you agree with anything in the end.
BugBear
Camber can be summed up as I said above: a deeper/narrower scoop takes more material away for same effort. That's the principle andin theory a semi circular cut would be the most efficient in terms of material removal. A scrub plane approaches this, but in practice it's not quite that simple - not least because you might use the same plane on different materials and anyway who wants semi circular grooves.
Oh you have got it!! Well done!!! Though I doubt it was proved by Archimedes.bugbear":2brq13ut said:.....We have:
A) The effort required for a cut depends purely on the length of the cut.
We also have
B) The shape of cut that removes most material for a given effort is a semi-circle.
This follows nicely from (A) and was first proved by Archimedes. Very basic,
well established maths.
If you bother to read what I wrote I said "in theory" and "it's not quite that simple" etc etcBut we also have
C) Factors other than the length of the cut effect the effort required.
