Kittyhawk
Oil change time on the truck.
The rubber gasket on the sump drain plug looked pretty bad so punched out a new one from some hard 3.2mm rubber sheet that I have.
The problem is that I don't know if the rubber is oil resistant. It is hard but can be dented a little with a thumb nail, has a shiny surface each side and thread mesh inset in the middle of it. It is I believe an industrial product used for gaskets and called insertion rubber. Should really buy a new one but none where I live and the vehicle needs to be back on the road pronto. Can anyone offer any advice or any way to determine if the rubber is oil resistant? Thanks
