I am trying to slowly put together a bit of a workshop, buying bits and bobs as I can afford them. So far I have a Triton workcentre with saw, router table, router and biscuit jointer. I primarily bought these as they also give me the option of working outside, up the garden, therefore not waking up the toddler whose bedroom is above the garage.
I have now also bought a EB BAS315 bandsaw, and could do with some advice regarding a new blade - I want to do some general ripping and crosscutting, but also cut curves and a little not too serious resawing. Am I better off with two different blades for resawing and cutting curves?
I also at some point want to get a benchtop planer / thicknesser.
At the moment I have a VAX wet/dry vacuum that I use with the triton gear, but obviously could do with something meatier and with 4" inlet to also use with the bandsaw and a thicknesser. budget is prime concern at this point, and will be looking to buy second hand. Am I better off looking for a shop-vac type system, or a chip-collector type? Certainly can't afford both.
Thanks guys
Simon.
Thanks guys
Simon.
