TheDudester
I am arranging to have a trial of a Domino Jointer for a day or so and would like to do something useful with it :?
I am building a workbench and wondered if using the Domino to create the mortice and tenon joints would be strong enough.
The construction of the base will be similar to this one here.
I do intend to use the space underneath for additional storage in the form of a plywood cabinet or something. For this reason should the stretchers be connected with coach screws instead of dominos, so I can lower them down when needed?
If any of you have used a Domino jointer, I would appreciate any help i.e. one domino or two on each of the joints, tight or loose etc.
Regards
D
Regards
D
