wrightclan":35xojj4r said:
You can buy a used Startrite for considerably less and upgrade or make your own higher quality fence later. That said, the fence that comes with a startrite, if not abused is not a bad fence. I only put a homemade Biesemeyer-style fence on so that I could extend the rails to get a 50" rip.
As for d*** blades :twisted: , Startrites (at least the"Tilt-Arbor" models)can take up to a 16mm blade. With a very simple modification (DM me if you wish) it can take a full inch set of blades. (The mod does not require any cutting or grinding of metal, nor does it require removal or adding on of any fixed parts.
Brad
thanks brad
but i have a set of dados with a 30 mm bore, i really don't wanna swap if i can help it,
i have looked at startrite and i do like what i see, only certian ones are fitted with a 30mm arbour, most if not all are, 15mm or 5/8"
i would like to know the mod just in case post it here with pics?
cheers ric
