donwatson
I think the reason the table is tilted is that the angle allows you see to see more looking down on the cut, if I can explain a bit more, if you sit and scroll with a flat table you are looking at the blade and th line of cut head on, if you raise the back of the table (and I have seen them at over 30 degrees), you get a much better view of where the blade is without a great deal of neck strain. Standing, and with the table at the correct height FOR YOU, and angled at around 20 degrees it practically eliminates neck strain.
Just my 'tuppence worth' but with some experience but behind it.
Don W
Don W
